- 9 Eki 2010
JBL GT5-12 1100W 30cm subwoofer'ımda kullandığım Harward marka amfiyi 3 senenin sonunda güzelce yaktım Şimdi Bu SONY marka amfiyi almaya karar verdim..Sizlerinde yorumunu bekliyorum
- [FONT=arial,helvetica,sans-serif]110W x 4 Max Power into 4 Ohms[/FONT]
- [FONT=arial,helvetica,sans-serif]150W x 2 (at 2 Ohms) + 300W x1 (at 4 Ohms) Max Power[/FONT]
- [FONT=arial,helvetica,sans-serif]60W x 2 RMS into 4 Ohms[/FONT]
- [FONT=arial,helvetica,sans-serif]65W x 4 RMS into 2 Ohms[/FONT]
- [FONT=arial,helvetica,sans-serif]High Level Sensing Power On[/FONT]
- [FONT=arial,helvetica,sans-serif]80Hz High Pass filter with -12dB/Octave Slope[/FONT]
- [FONT=arial,helvetica,sans-serif]80Hz Low Pass Filter with -18dB/Octave Slope[/FONT]
- [FONT=arial,helvetica,sans-serif]MOSFET Power Supply[/FONT]
- [FONT=arial,helvetica,sans-serif]RCA & speaker level inputs[/FONT]
- [FONT=arial,helvetica,sans-serif]Line level thru-put[/FONT]
- [FONT=arial,helvetica,sans-serif]CEA-2006 Power Compliant[/FONT]
- [FONT=arial,helvetica,sans-serif]CEA Rating: 60W x 4[/FONT]
- [FONT=arial,helvetica,sans-serif]DIN 45500 Rating (@ 14 V, THD 0.5 %)[/FONT]
- [FONT=arial,helvetica,sans-serif]4 ohm: 4 x 60W[/FONT]
- [FONT=arial,helvetica,sans-serif]2 ohm: 4 x 65W[/FONT]
- [FONT=arial,helvetica,sans-serif]Rated/THD (@ 14.4 V, 20 Hz - 20 kHz)[/FONT]
- [FONT=arial,helvetica,sans-serif]4 ohm: 4 x 60W / 1.0% (14.4V, 20 - 20kHz)[/FONT]
- [FONT=arial,helvetica,sans-serif]2 ohm: 4 x 65W / 0.1% (14.4V, 20 - 20kHz)[/FONT]
- [FONT=arial,helvetica,sans-serif]Maximum (@ 14.4 V)[/FONT]
- [FONT=arial,helvetica,sans-serif]4 ohm: 4 x 110W[/FONT]
- [FONT=arial,helvetica,sans-serif]2 ohm: 4 x 150W[/FONT]
- [FONT=arial,helvetica,sans-serif]Low Pass Filter: 80Hz[/FONT]
- [FONT=arial,helvetica,sans-serif]LPF Roll Off Rate: -18dB/oct[/FONT]
- [FONT=arial,helvetica,sans-serif]Subsonic High Pass Filter :: 80Hz[/FONT]
- [FONT=arial,helvetica,sans-serif]Input sensitivity: 0.3 - 6Volts[/FONT]
- [FONT=arial,helvetica,sans-serif]Frequency Response: 5Hz - 50kHz[/FONT]
- [FONT=arial,helvetica,sans-serif]Tolerance: +0 / -3dB[/FONT]
- [FONT=arial,helvetica,sans-serif]Total Harmonic Distortion (@1 kHz): 0.005%[/FONT]
- [FONT=arial,helvetica,sans-serif]CEA SN Ratio: 97dB[/FONT]
- [FONT=arial,helvetica,sans-serif]Min Load Impedance/Ch: 2 ohm[/FONT]
- [FONT=arial,helvetica,sans-serif]Current drain (@ Rated Power - 4?): 33 Amps (at 4 ohm)[/FONT]
- [FONT=arial,helvetica,sans-serif]Weight (approx.)(kg): 3.1[/FONT]
- [FONT=arial,helvetica,sans-serif]Dimensions (WxHxD in mm) approx: 396x55x256[/FONT]
